Reply To: Just got a Retrotink 2x. Only seeing vertical bars.
NewHome Forums RetroTink Products Just got a Retrotink 2x. Only seeing vertical bars. Reply To: Just got a Retrotink 2x. Only seeing vertical bars.
#39578
This means there’s no signal from your console. Check everything is connected correctly and that the game is properly seated in the console.
If possible, check that your composite or S-Video cable actually works by connecting it directly to the TV.
