CPS3 Digital Install issue
NewHome Forums CPS2 digital AV interface CPS3 Digital Install issue
  • #57732
    superchill
      I purchased a CPS2 Digital back in 2020 and just bought a QSB kit to install into my CPS3.
      After installing, I updated the FPGA to the latest cps3 firmware in Quartus. However, I am only getting lines for a picture. I am getting audio and the OSD menu is working. Continuity seems to check out and I am getting RGBs out of the JAMMA connector. I’m not sure where to go from here.
      Install photos here: https://imgur.com/a/lFr54rz
      • This topic was modified 1 year, 11 months ago by superchill.
      #57733
      superchill
        There is signal from C1 and C2 to the cps2 digital board
        C1
        C1
        C2
        C2
        #57739
          If audio and OSD are working stable, then the issue is unlikely to be in the clocks. Are the visible lines always in the same position or moving? You may want to test connectivity of HS and VS signals (maybe also at output of U16) since HS being stuck at 0 or 1 might cause an issue like that (only 1 out of 40 line buffers getting written).
          #57748
          superchill
            update: switched hsync and vsync and everything works – vsync was on IN1, hsync on IN2 🤯
            @marqs
            The lines on screen were moving.
            I looked at HSYNC and VSYNC out of U16
            hsync
            hsync
            vsync
            VSYNC_1vsync2
            • This reply was modified 1 year, 11 months ago by superchill.
            #57766
              Seems like the extra logic chip on some CPS3 boards has been wired differently. Probably should add a note on the instructions
