GameCube and GameBoy Player help needed
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support GameCube and GameBoy Player help needed
  • #42630
    snucker
      I seem to be having a hard time getting any video out of the OSSC using my GC other than the basic pass-through setting. I can see on my monitor that using pass-through the OSSC is sending me 720p video, I’d like to line2x my GC to get a sharper image on my monitor (should be 960p?). As-is, it looks really blurry.
      EDIT: I am using official component cables.
      #42637
        Not enough information. GC game or using GBP? Are you modifying any setting with Swiss?
        An output of 720p doesnt make sense anyhow, if the OSSC is set to passthrough.
        #42638
        snucker
          Currently I’ve only tested using GBP. I should see if a GC game works differently. My monitor shows a resolution of 720×480 coming from the OSSC, so I suppose it is 480p.
          EDIT: It’s a stock GC with official component cables, nothing else.
          If my monitor can support a custom 1440×960 60hz resolution is should support GC line2x from the OSSC?
          Custom 1440x960
          #42648
          snucker
            I get the same result while playing Metroid Prime in progressive scan mode.
            #42668
              It may be that your monitor does not support 480pX2 mode then.
              #42675
              snucker
                I’ll try on other monitors and my TV then. Would be weird though if I can set a custom resolution that is essentially 480pX2
                #42705
                  Depends on what the total line length of the custom resolution you tested. The output of linedoubled 480p on ossc would be 1716 samples (2×858) using dtv timing (using vesa timing would be incorrect for gamecube).
                  You could still try getting a better image from gameboy player by using GBI (Game Boy Interface), where you can get a 360p output that the OSSC can linedouble to 720p, or linetriple to 1080p. I’d recommend running it via Swiss.
                  Game boy interface high fidelity version
                  #42724
                  snucker
                    For Swiss and GBI I need a modded console though, correct?
                    #42734
                      No you just need an action replay disk and a SD-to-memorycard adapter, aka SD Media Launcher.
                      #42766
                      snucker
                        Harrumph, thanks for the tip. I was able to load Swiss/GBI with SSBM, I purchased a GameCube to SD memory card adapter and it’s working well. So far I’m able to get it to output 240p in line3x mode and it looks significantly better than the stock GameBoy Player disc. Any tips on how to get it to 360p line3x like you suggested?
                        #42769
                          Brief instructions Here, you can either use a separate cli file, or append the two needed options at the end of the dol file (use a simple text editor, but actually IIRC this is already done in the ”.dol+cli” file, which then is simply renamed to end with just .dol).
                          Personally I use the hdcustom setting, in contrast to hd60 it has barely any stutter because the framerate is so much closer to original. In that case modify file accordingly (the default in the gbi-ossc files is hd60).
                          #42860
                          snucker
                            Thanks!
                            #42937
                            snucker
                              Works like a charm Harrumph, thanks for all of the help.
                              #42947
                                Great!
