OSSC bleed colour. Bad black colour. How to get rid?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC bleed colour. Bad black colour. How to get rid?
  • #26028
    CloudVII
      http://i.picpar.com/Ibtd.jpg
      Down where the black is, which is yellowish colour. Not black.
      Is not a border, but a background does not make it black.
      I tested the old Samsung led with scart implanted ( no ossc ) and shows no yellowish. http://i.picpar.com/Jbtd.jpg
      So OSSC has bad black which gives yellow. Any tips
      #26128
        Never seen this before, it is maybe some TV setting that is different on HDMI to SCART input?
        #26131
          Could it be caused by a mismatch of the full/limited color setting?
          #26167
          CloudVII
            If you play Chrono Cross and speak to ai then you do not see transparent black, but brown yellowish. The ossc cannot make black background. It lacks ( create ) black background. But if you try old Samsung LED with scart, you will see it has black background and not brown, yellowish. Cannot say if Framemeister has black background.
            #26269
            CloudVII
              No one understand it. Another picture here.
              http://i.picpar.com/rjwd.jpg
              OSSC does not give black backround when dark. It gives yellow.
              Only led tv scart can give official black background. Means OSSC is not good.
              Or someone knows how to fix it?
              #26272
              paulb_nl
                Did you buy the OSSC from this shop or did you buy the Chinese version from eBay/AliExpress?
                Try to use a different TV or change the HDMI black level setting.
                #26274
                CloudVII
                  Why don’t you guys check your black background? Try Star Ocean PS1, which was mine .
                  #26321
                  Nodoka75
                    What are the firmware revision of your OSSC and your settings? It can helps to determine if it’s a software or a hardware issue.
                    #26336
                      It might be a defective unit, but before arranging a return with the place you bought it from, I’d test another console and/or display just to make sure the issue isn’t elsewhere
