This kit is for those of you that want to assemble an OSSC yourselves but are having trouble tracking down some of the more difficult to find components. Please note this is not a complete kit and you will still be required to source some components yourself. The PCB and case are also NOT included here, but can be purchased separately here.
As of 14/12/17 the kit no longer contains the component video connector as this is readily available here. Instead, we include 4 x 3M Mounting Fixings, suitable for the base of the OSSC unit, which can normally only be bought in minimum quantities of 56.
This kit contains the following components:-
4 x 3M Mounting Fixings (rubber feet)
1 x Altera Cyclone 4 chip (EP4CE15E22C8N)
1 x Aluminium cooling heat sink
1 x Component video connector (3 x RCA jack)
1 x Firmware chip (pre programmed)
1 x IT6613E HDMI interface IC
1 x Right angle type SCART socket connector
1 x TVP7002 IC chip
Note – Due to the extremely fragile nature of these components, each Cyclone 4 and IT6613E now ships in a padded Corstat component box. We have absorbed some of the extra cost of this packaging and only marginally increased the price of the kit.
For full assembly instructions and list of required parts/materials, click here.
