Note, this is a complex, intricate mod. Please study the fitting instructions at the bottom of the page carefully before you decide to order.
Breathe new life into your classic Atari Lynx hand held with this cutting edge LCD replacement. Replacing the dated original LCD with this new, vibrant model will make playing Lynx games a lot more fun, thanks to increased brightness, contrast, picture sharpness and improved battery life. Check out the picture below to see the difference the mod makes (click on the picture to see a bigger version).
What’s more, these kits provide a VGA output option, allowing you to play your Lynx games on your monitor or HDTV (VGA input or a suitable adapter, such as an OSSC, is required). Now, when you are home you can enjoy your favourite classic Atari Lynx games on the big screen too!
These replacement LCDs are the best on the market and have been specifically engineered for the Atari Lynx. Both Lynx I and Lynx II are supported. Unlike the Game Gear, the native resolution of the Lynx is a great fit for these new screens and no complex scaling is required. Apart from a tiny change in the pixel aspect ratio, the screens are a perfect replacement. You can even add an authentic scanline overlay by pressing the backlight button on the Lynx II or by turning the backlight thumbwheel on the Lynx I.
Our friends over at RetroRGB.com have done an in-depth review and test of this mod, check it out by clicking here.
Fitting Instructions
Note, this is a complex, intricate mod. Please study the fitting instructions carefully and only order if you’re completely confident that you can carry out the mod. We cannot offer refunds for mods damaged due to incorrect installation, nor can we offer technical support for installation of this mod. Please make sure your Lynx is in good working order before installing this mod.
Installation Guide – Atari Lynx I
Installation Guide – Atari Lynx II
A fitting service for this mod is available here.
