Reply To: HDMI Output Range & Format?
NewHome Forums RetroTink Products HDMI Output Range & Format? Reply To: HDMI Output Range & Format?
#23545
James-F
    Yes, that’s the input to the HDMI chip, the output from the HDMI chip may be something different than the input from the ADV7280.
    The OSSC for example is RGB Full Range 0-255, the RT2x might be something else.
    I assume it is the same as the 7280 output, 4:2:2 limited range.
