Neo Geo into Dell P2014H LCD
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Neo Geo into Dell P2014H LCD
- This topic has 5 replies, 2 voices, and was last updated September 10, 2018 at 10:15 PM by
videogameperfectionrocks.
September 8, 2018 at 1:51 PM #23085
I’m planning to hook a Neo Geo up to a Dell P2014H LCD via the latest OSSC. Neo Geo resolution is 320×224 and the monitor’s native res is 1600×900. Will 4x mode work or will the difference between 900 and 896 cause problems?
September 8, 2018 at 10:08 PM #23087Default output in 4x mode is 960 (4*240), You can set v.active to 225 for 900 output. If it works is another matter, but monitors are usually quite tolerant. Another issue is how the monitor scales input (ie it could force 16:9 output), again hard to know until you actually test it.
A bigger issue with neogeo is usually its total line output (264) and low reresh rate.
September 8, 2018 at 11:54 PM #23088Sounds tricky. Are there other parameters to experiment with if things get weird? Forcing 4:3 for example.
September 10, 2018 at 2:58 PM #23110Here what I’ve found:
2x stretches to 16:9
3x looks correct
4x is stretched and positioned strangely
5x is almost correct but cuts off just a bit of the left and right sidesI think 5x looks a bit better than 3x. Can I prevent 5x from cutting off the sides?
Also 5x only works when using an HDMI cable to the monitor. It doesn’t work at all if doing OSSC -> HD Fury VGA -> monitor. Can I make VGA work on 5x?
Or maybe I should be trying to fix the stretching and bad positioning on 4x since it’s closest to the monitor’s 1600×900 native res?
September 10, 2018 at 4:01 PM #23111Your display seems to always want to fill to 16:9. That’s why 3x and 5x looks correct but not the other two. You need to find the setting on your display for 4:3 (for 2x mode) or unscaled 1:1 mode (for 4x mode).
You can increase h.active (and decrease h.backporch to re-center the image).
You cannot force aspect on the display by any setting on OSSC. OSSC sends what it sends, the display scales to what it wants to scale.
That’s what I would go for. Note that you cannot get 4x output to 1600 active horizontal.* If you tweak v.active to 225, the output (active area) will be 1280×900. If your display has no way to display that 1:1, then this mode is not an option.
*(in 4x mode h.samplerate is 1560, which is less than 1600, and if you increase samplerate to above 1600 you will screw up the aspect ratio)
September 10, 2018 at 10:15 PM #23123My monitor doesn’t have 1:1 mode but I can’t quite grasp why that prevents me from using 4x.
Besides 4x, which line mode would you work to optimize on a 1600×900 LCD?
