240p/288p lineX4
  • #7699
    paulb_nl
      I know its already in the requested features list but it would be great if you could make it so that lineX4 would use a 1920×960 resolution. That way the monitor doesn’t have to do horizontal scaling.
      I have been testing that resolution with a total of 1048 lines on my monitor and it looks great.
      #7703
        I’ll try that out after implementing 480p linedouble. 1280×960 might be a better choice on average, though, as it’d have higher compatibility with 4:3 and 5:4 monitors (most 16:9 monitors should allow displaying that in 4:3 anyway).
        #7713
        paulb_nl
          Thanks! Unfortunately my monitor forces every resolution to widescreen so I hope you can include both.
