About the tolerance of capacitors and resistors
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – DIY & Repair Support About the tolerance of capacitors and resistors
  • #20661
    huluhala
      The BOM of ossc 1.6,GRM1885C1H300FA01D, 30pf, if the 1% tolerance is necessary? I have 30pf capacitors but the tolerance is 5%.
      And the tolerance of my resistors are 1%.:(
      #21125
      hinglecringle
        I believe the tolerance must be equal to or lower than what is on the BOM
