Accidentally plugged in to a 12v adapter, won’t boot
- This topic has 17 replies, 4 voices, and was last updated January 1, 2023 at 9:57 PM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – DIY & Repair Support › Accidentally plugged in to a 12v adapter, won’t boot
It’s hard to tell… cause most of the ICs and a lot of filtering caps are connected to the IOVDD line:
You can try to remove U4… maybe U8… and all the filtering caps connected to IOVDD and GND… before removing the bigger ICs. If you have the opportunity to borrow a heat cam, you could try to induce some low voltage into the IOVDD line and check for heat spots.
Thx Morpheus for your reply and highlighting the corresponding traces.
I checked the schematics already and figured out that indeed IOVDD is connected everywhere. Was hoping there was a likely culprit. The 12v probably triggered an over-voltage behind U5 which led to a short somewhere. ICs usually just fail without creating a short. Filtering caps usually just survive unless they are of the tantalum kind which short. Do we have tantalums anywhere on the board?
Anyway, I’ll keep checking, thx.
Btw. I got myself already a new OSSC but want to revive this one as well. One cannot have too many retro video converters 😉
No… we don’t have any tantalum caps on the pcb. And you are right: filtering caps usually don’t fail… but i’ve seen them fail in the past. And if some of the used ones are only rated for 6.3V, they may short out after a significantly higher voltage – unlikely but possible. It’s the same for the ICs: a short to ground because of the overvoltage is unlikely… but not impossible. But those should be the last ones to test…
