Alternative partner devices for OSSC other than the DVDO
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Alternative partner devices for OSSC other than the DVDO
  • #9684
    cruzlink2
      Just wondering if anyone can list what partner devices they have used with the OSSC for normalizing the signal other than the DVDO ones. I say this cause now the DVDO devices are hard to come by so if anyone has found another easier to get alternative it be good to know :).
      #9685
        I don’t think there is anything without a frame buffer, which means you’re going to be getting lag similar to, or worse than, an XRGB Mini.
        #9825
        b0nz0beavis
          How much lag do the various DVDO units add?
          And speaking of the XRGB Mini, would it normalise the OSSC signal? I know this would be a mostly pointless exercise (losing the OSSC’S superior colour handling and input lag) but it would make Sexy line-triple on incompatible displays (like Panasonic plasmas :'( )
          Edit: did some experimenting and the Framemeister does normalise Lx3, but the picture loses all its OSSC goodness and makes for a worthless exercise.
