Amiga and OSSC
  • #36974
    Anonymous
      I am trying to setup my Amiga to play games on my OSSC at x4. When I hook up my machine via OSSC, the picture looks good, but not perfect so I looked up some advanced timing settings which I found here:
      Advanced timing settings for Amiga
      I am assuming that these are the correct settings for normal games (not fancy hi-res for Workbench):
      PAL:HiRes, PAL:LowRes:
      240p/288p lineX3: Off
      H. samplerate: 908
      H. synclen: 60
      H. active: 724
      V. active: 288
      H. backporch: 77
      V. backporch: 24
      Sampling phase: Adjust until you get stable and crisp picture
      Once I enter these settings the picture and view the image at x4 line mode, it looks super narrow, as if it is half the width it should be, like this:
      BUT, if I switch to x2 line mode, then picture resolution looks fine:
      Am I missing something obvious? I am a n00b when it comes to OSSC 🙂
      Thank you!
      #36992
        What happens if you use the default settings for 4x?
        #36993
        Anonymous
          With default settings picture looks pretty good, even the ratio is fine. With the above settings picture looks sharper, but takes half the width.
          #37106
          uchristo
            Are you using a real Amiga or is the device in the Picture above a FPGA-based clone?
