Amstrad CPC "Active RGB" Cable advice
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Amstrad CPC "Active RGB" Cable advice
  • #19300
    nowayout
      Hi there,
      I want to use and Amstrad CPC with the OSSC. The question I have is regarding the rgb cable I was sent from ebay seller in a CPC scartcable/power pack combo. It says that is a new improved “active” cable which should help with being connected to modern displays. It wants the 5V power supply linked to the scart cable as in this picture: https://ibb.co/egYBO7
      My question is, will this be safe to plug into the OSSC? What benefit is the power supply supposed to have for the video connection?
      Thanks for any advice
      #19314
        Hmm, I’m not familiar with the CPC. It looks like from the drawing the power is going into the Amstrad? Is that a 5 volt input in the back of the CPC then?
        #19316
        nowayout
          Yes it is. I looked on the Web and seemingly the computer will work with ossc eg. here http://www.cpcwiki.eu/forum/amstrad-cpc-hardware/cpc-ossc-open-source-scan-converter/
          But there is no mention is power going into the scart. I’m obviously wary of trying it off it will harm the ossc..
          #19343
            Any idea what the +5v into the Amstrad is for?
            Power going into the SCART usually means a sync stripper, which shouldn’t be needed with OSSC.
