Any Dreamcaster can help me please?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Any Dreamcaster can help me please?
  • #18716
    MCLiLBas
      Hi guys,
      I have the OSSC 1.6 and I tried to get sound from my Dreamcast using a VGA Retro-bit cable but no sound.
      The VGA cable has a red and white cable attached, I plugged it in the Component ports in the OSSC 1.6 but still no sound!
      Am I doing something wrong? Do I need a specific cable for sound?
      Please help!
      Thank you!!!
      #18718
        Audio for AV3 needs to go in the 3.5mm port right next to it. The RCA connections are for component video on AV2 only. You will need a stereo female RCA to male 3.5mm adapter.
        You should give the manual a read.
        #18721
        MCLiLBas
          Thanks man! I have just ordered the adapter!
          #18772
          MCLiLBas
            I can’t get the sound of the Dreamcast to work using the OSSC 1.6, I purchased the stereo female RCA to male 3.5mm adapter and hooked up the female RCA with the male RCA that comes out of the VGA Retro-bit cable, and the male 3.5mm to where it says A3 IN on the OSSC, no sound at all!
            Can anyone help me please?
            Thank you!!
            #18773
              Is sound working/being digitised on other inputs/for other systems?
              #18775
              MCLiLBas
                Regarding the OSSC, sound works fine with other consoles but with using the SCART cable!
                I have never used the 3.5mm jack before since I mostly use SCART. However, for the Dreamcast, since I am using a VGA cable, I must use the 3.5mm jack to output audio as you know! I purchased the stereo female RCA to male 3.5mm adapter, hooked it up, no audio at all!
                #18776
                MCLiLBas
                  I updated my OSSC 1.6 yesterday to the latest version, I noticed that there is no audio settings in the newest update. Maybe I need to downgrade it?
                  #18777
                  MCLiLBas
                    When I upgraded the OSSC yesterday, I only downloaded the 79.bin update, however I see some update named 79.aud, is that for audio? i’m just confused!
                    #18778
                    MCLiLBas
                      It finally worked! because I wasn’t aware that I needed to download the aud update too!
                      Thank you so much for following up with me!
