Any way of having av2 act as BOTH scart audio output and component audio in?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Any way of having av2 act as BOTH scart audio output and component audio in?
  • #36910
    ENunn
      My Avermedia capture card is having audio issues and there’s no way to fix it right now. I need to have another way of routing audio until Avermedia has a fix for me. Is there any way I can have AV2 act as both Component audio in and SCART audio out? I can’t easily switch every single time I want to capture either component or SCART.
      #36918
        I’d say no. You could probably 3D-print a latch or something to make flipping the switch easier, but you’d still need to unplug the AV2 audio input to plug in the AV1 output and vice versa.
        If you’re already bypassing the OSSC for audio for AV1, then just route audio from AV2 to the same capture device and swap cables at that end, or buy a mixer that can take both sources and combine them for your capture device.
