Audio/Sound Delay issue with CPSDigi on OMVS
NewHome Forums CPS2 digital AV interface Audio/Sound Delay issue with CPSDigi on OMVS
Viewing 15 posts - 1 through 15 (of 21 total)
  • #57570
    Hiisoka89
      Hi there,
      I just tested my neogeo Open MVS with the CPS Digital installed on it, connected to my LG Oled CX tv via HDMI cable, but i got a very weird sound delay; the more play and time passes the more it becomes accurate and noticeable, and as you can see on the video it almost reached 1 seconde of delay which make it impossible to play…
      I tried to connect it using Retrotink 5X with a scart RGB cable + the same HDMI cable previously used with the same Oled tv and it worked without issue.
      Then, i tried to connect the device to my other tv (Samsung LED) using the same cable and it worked flawlessly without any issue.
      Here is the link of the video showing the issue https://youtube.com/shorts/tR7j_5EvzbI?feature=share
      Is this a known issue ?? Is the CPS Digital not compatible with some tvs (oled) ??
      Can anyone help me please ??
      Thank you
      #57577
        Very strange… do you have the TV set to game mode?
        #57578
        Hiisoka89
          Yes i tried with and without the game mode activated.
          • This reply was modified 1 year, 11 months ago by Hiisoka89.
          #57599
            Are you using the TV speakers directly or something like Arc/Earc?
            #57600
            Hiisoka89
              Tv speakers directly
              #57645
                Have you checked for a firmware update for the TV?
                #57658
                Hiisoka89
                  The firmware is up to date.
                  #57688
                    Did you have RT5x in framelock mode when you tested with it? Neo Geo’s lower than usual refresh rate (59.19Hz) might cause issues with some TVs.
                    #57689
                    Hiisoka89
                      Tbh i didn’t pay attention if it was on framelock but i have to mention that i got a DFO installed as well and the refresh rate is a 59.94Hz
                      Also i live in a country with PAL standards so my TV.
                      #57742
                        Hmm, I wonder if DFO is causing the issue here since presumably C1 and C2 clocks are no more exactly 12/6MHz with it. Consequently generated audio clock and sampling frequency are not as intended. I’ll need to take a look into details of DFO mod and possibly generate alternative firmware for it.
                        #57798
                        Hiisoka89
                          Thank you for your reply but it is normal that the setup works just fine with a non OLED model ?? Because with a LED samsung tv there is no issue.
                          #57810
                            Some displays may misbehave if audio sampling rate is 1.3% too fast, others are able to work with it. I’m now working on a update that adds support for AES and DFO. You can download a work-in-progress version here. From menu, change “XTAL freq” option to DFO.
                            #57886
                            Hiisoka89
                              How can i install the firmware ? Is there any turorial please ?
                              #57892
                                You can follow this tutorial as the process is same. For the USB Blaster, you can get the Terasic one or a cheaper clone which are available on Amazon etc.
                                #60154
                                Hiisoka89
                                  Hi, i just wanted to download this file you linked but the link is not working. Is there any recent version of it ?
