Audio/Sound Delay issue with CPSDigi on OMVS
NewHome Forums CPS2 digital AV interface Audio/Sound Delay issue with CPSDigi on OMVS
Viewing 6 posts - 16 through 21 (of 21 total)
  • #60161
      Which link is not working exactly?
      #60163
      Hiisoka89
        Some displays may misbehave if audio sampling rate is 1.3% too fast, others are able to work with it. I’m now working on a update that adds support for AES and DFO. You can download a work-in-progress version here. From menu, change “XTAL freq” option to DFO.
        The link you provided in your previous reply above.
        Also could you please help me i can’t get the usb blaster get detected by the quartus prime programmer, the pc detect it and all drivers are installed correctly but the quartus prime cant detect it, i tried in two different pc but nothing. The usb blaster is connected to the CPSDigi AV already installed in the OMVS
        #60165
        Hiisoka89
          I finally get it to work but i got operation failed for some reason when i want to install the flash.
          Do you have any idea what would be the reason please ?
          Also can you point out the link of the version of firmware i should install to solve the audio delay issue ?
          #60189
          Hiisoka89
            Could you please help me to solve this ? I tried in 3 different computers but i keep get the error cant access jtag chain.
            #60565
            Hiisoka89
              Hello,
              I really need your help guys! I just tried 3 newely received altera usb blaster but i’m still getting the same error message…
              Please help!
              #60876
                Is the MVS board powered on while doing the programming? Not sure if it’s related, but that USB Blaster is a clone so you should check others’ feedback from the store you bought it if such is available.
