Best OSSC settings for the PC Engine Duo RX?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Best OSSC settings for the PC Engine Duo RX?
Viewing 1 post (of 1 total)
  • #27161
    KentaZX
      I’ve been trying to use FireBrandX’s Ossc profiles for the turbografx and the PC Engine Duo RX. However his 320×240 profile still makes my image looks messy and not sharp, and his 256×240 profile isnt supported by my 4KTV apparently. (PC Engine Duo RX seems perfect in generic 4:3 setting though with 5X….is that a good thing or no?)
      Did anyone else had this problem before? what settings did you use? also, what games need those two resoutions specifically? or can I just go either one?
