Best Scan-line Settings
  • #26779
    JakeProtagonist
      Just bought an OSSC and am deciding what settings to use for scanlines on consoles ranging from 4th to 6th generation. Whats the best settings in the post processing menu?
      #26781
        This question is impossible to answer without knowing what your preferences for the look of the image is, what line multiplication mode you will use etc.
        #26783
        SavagePencil
          Other questions to answer:
          1. What type of device do you intend to view the games on?
          2. Do you intend to do any capture or streaming with these? Sites like YouTube, etc., don’t handle scanlines well. Something to consider.
          3. Are there examples of scanlines that you like? Examples of what you don’t like seeing?
