Best settings for component with Original Xbox?
NewHome Forums RetroTink Products Best settings for component with Original Xbox?
  • #42925
    SGTKilljoy
      it works fine on composite but not component. Right now it just gives me a rainbow test screen when i try to use component. What are the exact settings that are best? I tried turning off auto switch, multi region and force PAL60 but none of those resolved. Thanks for any help
      #42929
        Which RetroTINK are you using?
        #42939
        SGTKilljoy
          The 2x Pro
          #42989
          SGTKilljoy
            ok so i used another tv to change the settings on the xbox so it only shows 480p, but now on my Acer monitor it shows a double image, one on the left hand side and one on the right side. ive tried all settings and nothing resolves.
            #42992
            SGTKilljoy
              ok so i got it to look more normal, but over component there are red and blue blocks moving over the screen the whole time. this doesnt happen on component.
