Best way to hook up audio via component?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Best way to hook up audio via component?
  • #17864
    Flare
      I’m using component cables for my Wii and 480p/960p look great. The audio sounds a little off and was wondering if anyone knew of a good solution to get the audio to the ossc. I was using an rca to 3.5mm adapter for the A2 in port and it sounded like some audio channels were missing.
      #17869
        There is no better solution, if you have problems I’d look into your cable or adapter.
