Bug with optimized 720p modes and Sampling Phase?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Bug with optimized 720p modes and Sampling Phase?
  • #7591
    blizzz
      I’m playing around with my PSX at the moment. It’s a modded PAL console that runs at 59.27 Hz. The firmware is borti’s v0.70 with sound support, which is based on .69 I believe.
      The 320×240 optimized Linetriple Mode looks amazing after some adjustments to the sampling phase. After getting the right value for the sampling phase I reset the console and the picture came back very blurry, as if the sampling phase was way off. When I increased the sampling phase by one step and then decreased it by one again the picture was perfect once more.
      Does the sampling phase auto-adjust (to a wrong value) when you reset the console?
      #7594
        It resets every time you change out of the video mode. Root cause is a design flaw in TVP7002 digitizer chip when it is in PLLDIV2 mode. I’ll try to find a way to use these pixel-optimized modes without using PLLDIV2 so that phase setting wouldn’t be lost.
        #9007
        paulb_nl
          I have also experienced this with the advanced timing tweaker that I have to change the sampling phase just one step and back again to get a good picture.
          Is it possible to send the phase setting to the digitizer again after sync has been established to work around this issue?
          #9056
            A remote button for increasing phase 180deg could be best solution for this.
