Thanks for that. I could do with some more technical advice, but I’m not sure you can help to be honest.
I am using the OSSC in Line 2x (Generic 4:3) mode with a PAL 288p linecount 50hz source and an unusual artefact is visible on the TV (Panasonic TX58DX902B) screen. Essentially there is some kind of vertical banding visible on the screen which I have determined is not caused by brightness variations in the panel itself. I have also ruled out the panel’s FALD feature as a cause.
This evidently has something to do with the samplerate as the frequency of artefact changes as I alter it. Do you have any advice? See screenshots.
