Hello, I am trying to play Chrono Trigger (SNES version) using the OSSC PRO on Scaler mode, and I got this strange bug on the image:
Part of top side of the screen is like torn to the right, but it only happens when the dialog box is on the screen. If I switch to Line multiplier mode, it is even worse, because OSSC looses the sync when a dialog is present…
I remember to play it perfectly with the old regular OSSC. Do I need to set a special profile for this or it is a bug? Thanks.
Edit: I can add more information. My SNES is PAL SNSP-1CHIP-01 and I installed a long time ago this SuperCIC mode (no rgb bypass nor dejitter):
