Chunghop remote forgot settings
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Chunghop remote forgot settings
  • #57146
    kruuth
      My Chunghop remote that I use has forgotten it’s codes for some reason.  What do I need to do in order to fix it?  I don’t even remember the remote that I used to configure it.  Does it have codes pre-loaded or something?
      #57150
        Hopefully you’ve simply pressed the DVB or HIFI buttons by mistake, as they switch the remote to control other stuff. Try pressing the TV button on the remote and see if it fixes the problem.
