Colecovision Secam PAL
NewHome Forums Repairs and Upgrades Colecovision Secam PAL
  • #58670
    Roger Panepinto
      Hey. I installed a rgb Mod V2 from videogameperfektion in my SECAM collecovision. The install was easy but the colors not correct. I Check all the Connections and all ok. The Cable i use is from my PCE, and there it worked Great. What can i do?
      #58671
      Roger Panepinto
          It looks like you’re missing a colour. We will need some pictures of your install to determine if this is a fault with the PCB itself or the installation.
          #58673
          Roger Panepinto
            Roger Panepinto
              Roger Panepinto
                I check with a Multimeter. From PCB to DIN PORT. R has contact with PIN 7, G has contact with PIN 3 and B has contact with PIN 1.
                #58774
                TheCorfiot
                  Hi There
                  I would try reflowing the 3 signal inputs using some liquid flux.
                  I also notice that you are using a megadrive cable. These cables have inline components and its recomended you remove the three resistors on the tmsrgb board and jumper them instead. If your cable also has a csync inline resistor you will need to connect to the other csync pad on the tmsrgb.
                  If you have carried out the above and confirmed continuity on the RGB lines from the tmsrgb output pads to the scart plug pins then its possible the tmsrgb board is not functioning correctly
                  #58775
                  Roger Panepinto
                    Thank you very much, today i try it when i am at Home. 👍
                    Regards
                    Roger
                    #58826
                    Roger Panepinto
                      Hey. Same result 😩. I remove the resistor on the PCB, and use TTL. I also resolder all the Pins and Check the connections.
                      Regards
                      Roger
                      #58856
                      Roger Panepinto
                        I find out, if i press Reset many times the colors often changes. And sometimes the are correct. What Could it be?
                        Regards
                        Roger
                        #59668
                          Turns out this was a faulty board and a new board was sent to the customer.
