Colour issue using my new OSSC Pro with a DOS PC – no problem with OSSC v1.8
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Colour issue using my new OSSC Pro with a DOS PC – no problem with OSSC v1.8
Viewing 6 posts - 16 through 21 (of 21 total)
  • #64840
      Do you have a VGA cable where pin 4 is tied to ground?
      #64842
      Merkurio
        Hi back BuckoA51,
        No, my both VGA-cables I own, pin 4 not tied to ground
        #64844
          It was not entirely clear from the previous answer if pin 4 in your cables was connected (to the same pin on other end) or not connected at all as listed in the picture. If you have a cable with pin 4 floating, then both Classic and Pro should appear the same way to the source.
          #64847
          Merkurio
            Hi back marqs,
            Yes, pins 4 on both sides of the cable are connected together. And Pin 4 is NOT connected to GND (pin 5). Only pins 6, 7 & 9 are connected together.
            #64848
            Merkurio
              … I posted the picture just for numeration of the pins, I refered to.
              #64849
              Merkurio
                … sorry correction to #64847: Only pins 6, 7 & 8 are connected together.
