Connecting Multiple Inputs To Koryuu With A Switcher
NewHome Forums Koryuu Transcoder Connecting Multiple Inputs To Koryuu With A Switcher
  • #41264
    90sGamer
      So I have multiple composite/s-video systems I am trying to run through my OSSC via the Koryuu. I am wondering if it is possible to run a switcher to the Koryuu instead of a single console. I have a Pelican composite/s-video switcher, as well as a gcompsw component switcher (which also accepts a composite input) at my disposal. If that works, then there are the red/white RCA audio inputs left to deal with, since the Koryuu only accepts video inputs, and since the two switchers are already connected directly to the OSSC, would those just simply remain plugged into the switchers? Thanks for any help!
      #41291
      megari
        Hi!
        I do not see any fundamental issue that would prevent using a switcher, provided excessive noise is not introduced. If the Koryuu is outputting video to the OSSC, the audio inputs can remain connected to the OSSC.
