Convert 50Hz RGB PAL to 60Hz for display on NTSC HDMI TV using OSSC
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Feature Requests Convert 50Hz RGB PAL to 60Hz for display on NTSC HDMI TV using OSSC
  • #16973
    grips03
      Convert 50Hz RGB PAL to 60Hz for display on NTSC HDMI TV using OSSC.
      Videopac+ G7400 is 50Hz RGB PAL only console, there is no 60Hz NTSC model. OSSC currently does not convert 50Hz to 60Hz, so displaying image on NTSC TV is not possible. This feature request would provide the conversion.
      #17032
        Is framerate conversion like this even possible without a framebuffer?
        #17077
        grips03
          Yes, I think it would be possible. There are $20 adapters that convert PAL to NTSC and I don’t think they have a frame buffer in them. I certainly could be wrong. Can marqs reply to say if this is possible or not?
          #17079
          grips03
            Looks like it might not be possible, see 3:2 pulldown
            https://en.wikipedia.org/wiki/Three-two_pull_down
            Marqs if you can reply to be certain that would be great.
            #17319
              Framerate conversion requires a framebuffer and always introduces stuttering or tearing.
              I believe the $20 devices you’re talking about simply correct the colour carrier in composite, allowing most NTSC TVs to display them despite the 50hz
