Custom Horizontal Sampling for 240p/288p Content
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Custom Horizontal Sampling for 240p/288p Content
  • #10692
    jamesfmackenzie
      Because of the unusual width, I’ve also had issues capturing Atari ST Medium resolution (640×200).
      I’m hoping the OSSC (with its capability for custom horizontal sampling rates) can help me with this.
      However looking at the docs on JunkerHQ, it seems horizontal sampling is only adjustable for 480p content:
      “Selectable sampling configuration for 480p input: DTV-480p or VGA 640×480”
      Can you confirm if custom sampling is supported for 240p/288p content and whether it could help me with Atari ST Medium res at 640×200?
      Thanks!
      #10698
        It’s in the sampling options/advanced timing
        http://junkerhq.net/xrgb/index.php/OSSC#Advanced_timing_tweaker
        #10699
        jamesfmackenzie
          Ah, great! So can you confirm that this custom sampling will work for 240p/288p input? I don’t have an OSSC to confirm myself (yet!!)
          #10705
            No, I don’t have an Atari ST. Theoretically, the OSSC should do it fine, it’s more up to the display if it would work.
            #10713
            jamesfmackenzie
              Thanks! I intend to pump the output through a Micomsoft sc-512n1-l/dvi, which should be generous on the timing
