DeJitter AND SuperCIC together?
NewHome Forums Repairs and Upgrades DeJitter AND SuperCIC together?
  • #23301
    dreimer1986
      Haaay, I just bought the SuperCIC and DeJitter and now realized that both tinker with the frequencies. Now is my question what to do? Before my 1Chip SNES Jr. looked sortof fine on OSSC which I bought from you too. Now it’s a mess. https://photos.app.goo.gl/Q1mmagRegdoJAU5u5 Ignore my german, it was meant for ikari ^^
      https://photos.app.goo.gl/m6FXkbdMoU8tP51d7
      https://photos.app.goo.gl/S1K3VWoVoA3aJnNC9 (At first I soldered the wire to the wrong pin of X1 because your manual is… special in explaining that stuff…, fixed now and working as it seems)
      https://photos.app.goo.gl/GTfuEDteLo6gvNLp6
      https://photos.app.goo.gl/XCZ2x5bZpYUWgLcx9 (Isolated orange wire is Sync from SRGB, I currently use another which worked better in the past seen on pic 2 above SCPU)
      https://photos.app.goo.gl/ptAuL23BZ5jvPwmd9 (Yeah, fixed fuse which was blown years ago by using another PSU with wrong polarity)
      Problems can be seen in video and the funny thing is it worked with a stupid 50/60 Hz switch mod on same hardware. ikari meant that the capacitors are maybe a lil small next to the NTSC oscillator and he meant to add another 55 pF to one of em piggyback. But he also meant that the DeJitter might help me, but was rather shocked that it uses it’s own NTSC quartz and thus cannot be used with the SuperCIC board together. At least not easily. Now it may question… how to fix it? It flickers way less on Framemeister (once every 5-10 sec), but still far from fine. HAAALP
      #23302
      dreimer1986
        Found out myself. CLK_SEL_I on DeJitter needs to be soldered to Mode on SuperCIC, too. MCLK_EXT on DeJitter needs to be soldered to X1 CLK on SuperCIC and MCLK_o needs to be soldered to X1 on SNES. Thus you solder the DeJitter in between your normal wire between X1 and X1 CLK on SuperCIC. Poof, working SuperCIC AND working on OSSC ^^
        #23305
          Yep they definitely work together I have both in my SNES 🙂
          #23384
          Decoryah
            Do you have any pictures or more detailed instructions of installation of DeJitter and SuperCIC mods together?
            #23385
              Not currently I’m afraid, I’d welcome any users photos.
              #23386
              Decoryah
                I would appreciate it if someone has done it and would be kind enough to send some pictures of the process or finished installation. I just purchased DeJitter Mod and my modder friend asked for more detailed instructions for this particular case. My plan was to have it modded to my USA Snes Mini that has RGB and SuperCIC mods already in it.
