DExx-vd_isl fw 0.62
  • #55768
      DExx-vd_isl firmware v0.62 is now available for download. Most relevant updates since last release include
      * added Auto aspect ratio option
      * added 480i & 576i CRT modes and moved CRT output modes under dedicated option
      Those who are planning to update by .rbf file replacement should also replace u-boot.scr on SD card with the latest version which slightly reduces power consumption of the HPS portion of FPGA.
      #56202
      Analog Dude
        How do you flash to a sd card? It’s not a bin like the usual OSSC updates.
        Flashing the linked firmware file seems to have permanently damaged my micro sd.
        #56218
          Initial SD card preparation and subsequent fw update procedure is described in the wiki. Flashing wrong file probably just made the card disappear from PC file manager and you need to re-flash it proper image.
