Display to show settings altered when remote hotkeys pressed
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Feature Requests Display to show settings altered when remote hotkeys pressed
Viewing 1 post (of 1 total)
  • #15624
    BubbaMc
      It would be helpful if the display showed the result of pressing the remote hotkeys as follows:
      SCANLINE_MODE
      SCANLINE_TYPE
      SCANLINE_INT+/-
      SAMP_PHASE+/-
      When using the onboard menu navigation it’s clear what the resulting settings are, however when doing the same with the remote hotkeys, I don’t have any feedback of what the new setting is.
