Dreamcast VGA input problem, Green image
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Dreamcast VGA input problem, Green image
  • #43603
    pit_2046
      I connect Dreamcast to Ossc as
      Dreamcast -> VGA box -> OSSC -> HDMI input to Monitor.
      The screen is in Green
      View post on imgur.com
      It has no problem if I directly connect Dreamcast -> VGA box -> VGA input to Monitor.
      OSSC has no problem for Component / Scart input too.
      Is OSSC got any defect? Can I repair in on my own?
      Thx
      Pit
      #43650
        It looks like the OSSC has simply been set to expect YPbPr input rather than RGB over the AV3 input. Reselect the input with either the digit 3 button (AV3 – RGBHV) or the digit 9 button (AV3 – RGsB) on the remote, or press BTN0 on OSSC itself until you get to AV3 RGBHV or RGsB. One of those should hopefully work.
        #43656
        pit_2046
          Thanks for your reply.
          I have already used AV3 – RGBHV input.
          It show this error Green Image.
          Other selection has no any graphic shown.
          #43733
            If you bought it from us, get in touch and I’ll check the warranty.
            #43981
            pit_2046
              Merry Xmas.
              It was bought from your website.
              I have sent you the invoice by email.
              Let me know if what I can do. Thanks.
