Earphone jack overrides scart input?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Earphone jack overrides scart input?
  • #27252
    kruuth
      I have my PS2 plugged in via the RGB cables and the audio in via the earphone jack on the side. When I do this, I don’t get audio across the scart connection. Is there something I need to do? If this is an issue, I need more scart connections. Is there a recommended scart selector with 6+ connections?
      #27258
        That TRS jack to the right of the SCART input serves as an analogue audio breakout for AV1 OR an audio input for AV2, which is determined by a small switch next to it; it cannot function as an audio input for AV1. Generally, SCART carries both audio and video, so I think it’s a little unusual to need to separately connect audio when using SCART.
        Additionally, I believe when you connect something to that TRS jack when it’s set to be an audio breakout for AV1, the OSSC will not also send that audio over HDMI; so, if your SCART cable already carries audio, and you’re connecting something else to that TRS jack, that could be why you’re not getting any audio.
