Firmware 0.84
Viewing 4 posts - 16 through 19 (of 19 total)
  • #27848
      The stardard fw image should for fine for most, the issues probably occur only to some users who happen to have slightly slower silicon (for which the alternative image seems to be a solution).
      #27850
      BlueStinger
        Hello, I think there’s an issue with the newest firmware. I’ve only encountered this issue with PAL PS1 so far.
        The issue : tiny green blinking artifacts (like, between pixels)
        I haven’t experimented much with it and it didn’t show up with the 240p Test Suite. I’ve tweaked the optimal timings and fired up FF7 and saw this issue, tried FF8 and saw the same issue. Honestly, it looked like an HDMI cable issue but I’ve replaced it and the issue is still here. I’ve downgraded to v0.83 and the issue is now gone so I’m pretty confident it comes from the latest firmware update.
        If you want to replicate it :
        Legit OSSC bought from VGP
        PS1 PAL + CSync cable from RGC.com
        x5 1920×1080 (as well as other resolutions) in 320×240 opt mode
        my sample rate was 426.25 (doesn’t seem to matter anyway)
        Remember, everything was fine in the 240p test suite, FF7 and 8 will be problematic for sure (I mean, they were for me, so I assume they would behave the same way for you)
        Like I’ve said, I haven’t experimented much with this bug as I wanted to see if downgrading the firmware would fix the issue.
        I hope this helps (I know I’ve just complained but great job Marqs, I’m a huge fan of your creation, I think that the OSSC is the coolest thing I’ve ever owned)
        #27853
          Try the alternative build linked here a few post back. That should fix the issue,
          #27854
          BlueStinger
            Thanks mate, I’ll try that !
