Firmware v0.80
Viewing 15 posts - 1 through 15 (of 15 total)
  • #19786
      Firmware v0.80 is out:
      * PCM1862 audio ADC parameters corrected (fixes audio quality issues with certain systems, e.g. some MD units)
      * audio gain setting added (pre-ADC, +-12dB range)
      * video test pattern updated (32 step grayramp)
      * profile link option added (allows binding a profile to each logical input)
      #19795
        James-F
          Thank you!
          Friends don’t forget to create a “OSSC Settings.txt” on you computer and save your hours of tweaking.
          Like so:
          240p Linex3 (960x240)
          H. Samplerate : 1254
          H. Synclength : 54
          H. Backporch  : 174
          H. Active     : 960
          V. Synclength : 3
          V. Backporch  : 15
          V. Active     : 240
          #19802
          SirRockALot
            Maybe marqs should add password saves to the OSSC 😉
            #19825
            jonlad
              Updated! Works great, thanks for working on that Marqs.
              But good grief, what a pain in the arse to write down all settings from each profile and then enter back in….
              #19830
              paulb_nl
                Thanks again Marqs!
                #19831
                Damn-Deal-Done
                  This has fixed the odd digital noise for me. VA1 NTSC-J Mega Drive. Thanks
                  #19859
                  polyh3dron
                    I can’t wait to try this with my SNES Jr / SD2SNES combo to see if it fixes the noise.
                    #19882
                    mcmarty
                      I have just updated to 0.80a and my OSSC has stopped reacting to my remote control commands.
                      The green led flashes when a command is sent but the OSSC does nothing.
                      The remote is working fine and I have double checked using my Harmony remote to no avail.
                      The OSSC is still passing through signals from all inputs and the on board buttons are cycling through the inputs without any problems.
                      Has anybody else had a similar problem?
                      Is there anyway to rollback the firmware without a remote?
                      Any assistance would be gratefully received!
                      Oh, first post as well, hello everyone 🙂
                      #19894
                      mcmarty
                        Hello again,
                        I managed to fix the problem by holding down BTN1 at power on and then re-training the OSSC’s remote commands.
                        Perhaps I should have done a tad more research before my panic stations post above!
                        Phew, now on to trying to force my monitor (Predator XB27HU1) to display above 3x mode.
                        Cheers,
                        M
                        #20004
                        Braca862
                          I think the firmware update made the issue with the SNES even worse. The display now flickers constantly, making the SNES unplayable on my TV.
                          #20011
                          mrblack1
                            Hello, i just received my ossc, but how can i download the firmware ? impossible to downdload, the link doesn’t work ! help !
                            #20015
                              NES/SNES compatibility with certain displays seems to be affected by firmware versions despite no relevant RTL changes (Quartus always does full recompilation of the design, though). Timing constraints have been rewritten for the next fw which might help with good luck, but fixing the root cause is the only certain solution.
                              #20016
                                Not seeing any issues here what specifically isn’t working for you?
                                #20017
                                mrblack1
                                  it’s ok i didn’t understand that it was the bin file that i have to download, but i have another big problem : my remote doesn’t work at all !!
