French ossc master system
  • #50624
    Maclein
      Hello I have a French master system and not long ago I have acquired an ossc, I would like to know if there is any configuration or if you have to use another cable that is not the rvb that I have from the console since the console starts up you hear but you do not see anything , I have looked and tried to manipulate configurations to see but the ossc does not send me video but only audio someone could remove my doubt if the ossc can work with the French I have version 0.88a in the ossc thanks
      #50634
        OSSC supports only RGB not composite video, so you must use an RGB cable.
        #50784
        paulb_nl
          Apparently the R.V.B adapter that comes with the French Master system is an RGB cable.
          Try to adjust the Analog sync Vth value in the Sync opt menu.
          #50793
          Maclein
            Hello, thank you very much, finally I could see you regulating the synchronization vth thank you very much because I was desperate with the matter, the truth is that you have helped me to solve it a thousand thanks
