I recently update my 1.6 OSSC from 0.81a to 0.82a and am now experiencing issues when using 240p5x and 480i4x. I’m using a PS2 outputting through component using HDRetro cables and a high quality HDMI cable (tried 2 just to make sure although it worked fine before). Whenever I switch from 240p4x or 480i2x to 5x and 4x, the screen becomes mostly green as if I chose the RGsB setting as the input for AV2. I am not able to test this with RGB as I do not own any RGB cables, however this does happen with component input from other consoles. Perhaps there is some setting which I have overlooked or am ignorant to so feel free to enlighten me. I’ll also try downgrading the firmware to see if this issue goes away or not but it did start after I upgraded (or at least in that time frame).
EDIT: Also note that in 240p5x and 480i4x the Green screen is present for both Component and RGsB modes, when switching to RGsB mode it appears to improve the resolution.
EDIT2: After Downgrading the problem still occurs when it previously had not. Perhaps some setting was reset when updating it all that I can think. Will update if anything changes.
