Has my OSSC failed?
  • #15653
    Deleted User
      Hi, strange issue…
      After 2 weeks of working perfectly i fire my OSSC up today and there is no output (not even test pattern)
      3 TV’s later that were working and 3 different HDMI cables i still get no output.
      The only way i can get any output is changing TX to DVI (even when using HDMI) but the image is flickering and mostly green and its the same for all TV’s
      Any options i can try or has the HDMI output failed?
      View post on imgur.com
      Thanks
      #15657
        Yep I’m afraid so, that’s a problem with one of the ICs most likely. E-mail in and I’ll sort out an RMA.
        #15674
        Deleted User
          Ah bummer! Cheers, have sent in an email
