I bought this HDMI switch that works but when I have my PS4 turned on, the power from its HDMI cable gets routed by the HDMI switch to the OSSC plugged into input 2 and causes the OSSC backlight to flicker. This works even when the OSSC is switched off and unplugged.
My DVI switch never did this, and I was already cautious about this HDMI switch because I didn’t like how it was using the HDMI signal to power an LED light.
I tried really hard to find an HDMI switch that worked like my NEXT DVI switch, with two mechanical switch buttons and no power input. The only ones I could find are this and this. You will need to search them on ebay. I was able to find the radioshack one on ebay and will test once it arrives. The only thing I don’t like about the radioshack is that it still uses LEDs, but the two button mechanical switch implies its internals have proper signal separation like the DVI switch that I have.
I tried to avoid any of the single push ones and virtually all of them are like that. If the one I got backfeeds voltage to the other input, it is likely all of the others on the market with a similar single push design do the same thing. I did get one more single push switch with three inputs on amazon just to test but I’m expecting it to have the same issue.
