Help Please
- This topic has 2 replies, 3 voices, and was last updated September 1, 2018 at 10:21 AM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Help Please
Good Afternoon,
I’ve been searching but not sure I understand what’s going on. When playing through my projector on 1x and 2x the screen is filled too and bottom it’s a standard 4:3 aspect so I’m happy with the bars left and righ. As soon as I play a lot of the consoles on 3x 4x and 5x the top and bottom of the screen isn’t filled. Can it be adjusted or is the the resolution of what my projector is receiving that cannot be adjusted?
Images are too small to really see what’s going on but it may be as you suspect, just how the projector is scaling things. Unless there are settings on the projector there may not be a way around it. On the OSSC, you can try fiddling with V.Active in the advanced timings.
Only x5 mode crops the image at default 1080p setting (can be changed to display full 1200 vertical image).
It must be your projector doing the cropping.
Edit: sorry didnt see Bucko had already answered
