Hookup to Iscan HD+
NewHome Forums RetroTink Products Hookup to Iscan HD+
  • #22481
    doonut
      Hi everybody,
      I have some problem when I try to hookup 480p from 2x to HD+. the DVDO cannot detect any signal for 2x.
      If you guy has any solution, please kindly let me know.
      Cheers!
      #22492
      mikechi2
        Dumb question – does the device work on a normal display? Just a random shot, but maybe running it through a HDMI splitter will regenerate the signal enough for the DVDO.
        #22532
        doonut
          Hi Mike,
          Yes, it works on a normal display. I tried the cheap one hdmi splitter box from China but still doesn’t work.
          So I found the solution to hookup to dvdo.(2x-> hdmi2vga with power -> d-sub2comp-> dvdo (work!) the picture crisp and clear but sometimes the signal unstable. the picture disappear on the screen.
          I think you are right. they need more signal strength for the dvdo. what do you think in the link down below?
          https://www.radioshack.com/products/radioshack-hdmi-extender-repeater
