How difficult will it be to build this thing?
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – DIY & Repair Support › How difficult will it be to build this thing?
- This topic has 9 replies, 4 voices, and was last updated September 3, 2018 at 6:25 PM by
Morpheus_79.
December 7, 2017 at 11:02 PM #17879
After researching online the OSSC seems to me by far the best option for a quality retro gaming upscailer.
I notice the assembled unit is now back in stock, but that you can also buy a DIY kit.
Building it yourself is obviously a lot cheaper, however, I don’t really have much soldering experience and I’d have to buy a new soldering iron; aswell as sourcing parts that are not included in the two kits on the store.Clearly I do not have the knowledge or the equipment to do this, but maybe I could do?
Could I learn this stuff with not years of experience, and considering I’d have to get a souldering iron would it even end up cheaper?Thanks a lot!
December 8, 2017 at 7:33 AM #17887It’s not necessarily difficult, but it can be expensive and will take time and effort. I found it was very rewarding though.
If you do your research properly, and have decent solder skill, you’ll be fine. The main items you’ll need are:
– temperature controlled soldering iron
– x10 magnification (for checking for solder bridges on ICs)
– x3 magnification lamp (for soldering the SMD ICs, resistors and capacitors)
– solder wick (3mm is good)
– 0.5mm soldiering wireSkills you should search for tutes on YT:
– SMD fine pitch soldering
– using solder wick (essential for SMD fine pitch soldering)Buying a decent temp controlled iron can mean you end up spending more than what you would for an assembled OSSC. But it is a lot of fun and you might just end up using the iron for other projects.
My 2 cents worth – if you can spare the cash, you should it. You don’t need elite soldering skills, just a steady hand and the right equipment.
December 8, 2017 at 2:02 PM #17892Thanks for the reply, that helped a lot.
Do you have any brand recommendations for the equipment?Also, is it complex to read the schematics for the instructions?
December 8, 2017 at 5:28 PM #17894Weller, JBC, Ersa and Hakko are generally good brands to choose your soldering station from. There are some Chinese Hakko clones out there for a budget price, which will do a pretty descent job too:
… especially when equipped with an original Hakko soldering tip (which indeed fits on those clones).
You don’t necessarily need the schematics to build your own OSSC. Essentially you just need the bill of materials (BOM):
https://github.com/marqs85/ossc_pcb/tree/v1.6/bom
There you can find the designators for every part, which are printed on the PCB itself too. That way you can see where every part belongs to. You just have to keep in mind, that the ICs have to be soldered with their marking showing in the right direction and that some parts (like diodes) have to be soldered with respect to the right polarity.
December 8, 2017 at 8:51 PM #17898Thanks for the response, I’ll take a look at those brands. I have a Weller iron but it doesn’t take a fine tip as is needed. The one in the video looks very interesting.
The parts list you linked: Is that absolutely everything you need, then? Does it include the bundle you can buy here on the site?
December 9, 2017 at 5:17 AM #17905The list does include everything you need… except (of course) the pcb, the acrylic plates for the case, the power supply and the programmable remote. The advanced bundle kit contains:
● the Altera Cyclone 4 chip (EP4CE15E22C8N = on the BOM)
● the A/D video converter chip (TVP7002 = on the BOM)
● an aluminum heat sink for the TVP7002 (= on the BOM)
● the component video connector (= on the BOM)
● the IT6613E HDMI interface IC (= on the BOM)
● a right angle type SCART socket connector (= on the BOM)
● the pre-programmed firmware chip (S25FL216K = on the BOM… but – of course – it’s not pre-programmed with the OSSCs firmware, if you buy it from a wholesale supplier like Mouser)If you are buying the advanced kit, you need the simple DIY kit too, since the advanced kit does NOT include the pcb and the acrylic plates (and as mentioned: they are both not on the BOM).
The simple kit contains ONLY the pcb and the acrylic plates. If you are planning on just buying that (and since only the advanced kit contains a pre-programmed firmware chip) for the simple DIY kit you also need some equipment to write the firmware onto the flash memory chip… as i described here:
A cheap USB Blaster clone (for around 3-5 bucks) and an older version of the Quartus Prime software (i did use v13.1.0.162) will do the job just fine.
No matter if you are buying the simple or the simple AND the advanced DIY kit: you have to buy a stabilized 5V power supply too (with a 2.1 mm barrel jack and with at least 1A output), if you do not have any.
Since neither of those kits include a remote control, you may need to buy one too. The remote is kind of a tricky part. You can buy a ChungHop L336 learning remote (as delivered with the pre-build OSSC) – but it has to be mentioned: the L336 needs a compatible remote to learn from. BUT if you already have such a compatible remote (that is recognized by the OSSC), you don’t necessarily need the L336 in the first place. So it is kind of a weird loop. But at least chances are pretty good, that you (or someone you know) owns a compatible remote control to make the L336 learn from…
December 10, 2017 at 9:44 PM #17931Thanks for the detailed reply.
So rather than searching for the parts on the first list you linked, could I just buy the simple DIY kit, advanced DIY kit, power supply and remote? Would that be everything?Also, is the remote control an actual requirement or just something recommended? I was unsure as to whether I could control the device on the hardware its self.
EDIT: Do you think this soldering iron would be okay? It’s the same brand as the one in the video but not the same model: https://www.amazon.co.uk/YiHua-Soldering-Station-Welder-Repairing/dp/B074Z84TDL/ref=sr_1_3/257-9277959-4901744?s=diy&ie=UTF8&qid=1512938907&sr=1-3&keywords=yihua
I couldn’t find the model in the video here in the UK.
December 10, 2017 at 11:01 PM #17937So rather than searching for the parts on the first list you linked, could I just buy the simple DIY kit, advanced DIY kit, power supply and remote? Would that be everything?
No… not even close. You still need to buy the capacitors, resistors, fuses, voltage regulators, oscillators, connectors, buttons, diodes, the display, the IR receiver and some more parts.
If you open the BOM Excel file (you can use Microsofts free Excel Viewer or Open Office Calc): everything marked red is part of the advanced kit… everything else you still have to buy from a supplier of your choice.
The OSSC only has two buttons and the controllability of the OSSC with those two is very limited:
http://junkerhq.net/xrgb/index.php?title=OSSC#PCB_buttons
As you can see: without the remote you can only chose the input connector and the scanline mode… but not much more. So if you want to configure or even fine tune the input and output settings, you HAVE to have a remote.
Don’t look for the brand name. Chinese sellers sell the same soldering station worldwide under 5, maybe 6 (or even more) different brand names – like Atten 936, YaXun 936, Aoyue 936, Uluo 936, LionKing 936, Quick 936, and so on, and so on… even WITHOUT any brand name at all:
https://www.amazon.co.uk/Electronic-Soldering-Station-Degrees-Temperature/dp/B00JRD08P8/
Since it’s a clone of the pretty descent classic Hakko 936 soldering station, they always keep the ‘936’ while changing the brand. You should definitely buy an additional genuine Hakko 936 tip, since the chinese soldering tips are usually pretty crappy and wont last very long.
September 3, 2018 at 10:39 AM #23040Sorry for reviving a year-old thread, but this is probably the most applicable. and it’s only the 2nd page in…
After buying this over a year ago (1.5 version) I finally have time to try and build it (well, I had time before but the parts didn’t come till like, half a year later).
What I can piece together from the instructions are (not much)…
-schematic — contain pinouts for the chips and connectors
— Case assembly – pretty straight forward
Stencil — ??? – I don’t recognize these file formats
BOM -> I’ve bought everything here.
Kit contents (nothing’s missing)
Assembly tips. (ok, i’ve read through it)labels – which appear to label the joints but not what’s supposed to go there, (would seem to be useful when communicating but nothing references these labels)
Traces — Pretty illegible for me, everything overlaps, and font appears pixellated in a way which i can’t read it.
and a wrl file — google search shows that this is probably a 3d model? — which I don’t have the software to open, and i’m not looking forward to finding one and learning how to use it…
Basically Other than the obvious giant slots for the chips, I have no idea where everything goes…
I’ve worked on arcade boards, consoles, and done mods for them for a few years. So I figured I could put this together
I’ve never come across “instructions” like this before. Can someone point me in the right direction?
I have a feeling the traces file tells me where everything goes (TOP is much more readable than bottom, i can make out a couple of caps, and a couple of resistors), but the bulk of it is seriously is illegible for me. Is there a larger version where the text is less pixellated?I guess I just have no choice but to just find software to open the 3D model and learn to use whatever software I get?
I’ve just ordered an assembled 1.6 But I’d still like to put together this 1.5 so I have an extra one for running events and as backup.
I recall before I made my original purchase I came across a more detailed workflow than the “example” in tips which did lay out and describe where all the parts go — With better diagrams. But I can’t seem to find that anymore.
September 3, 2018 at 6:25 PM #23056Stencil — ??? – I don’t recognize these file formats
Those are Gerber files for creating a solder paste stencil. You can order one from most PCB manufacturers…
I don’t know, what you mean. On the BOT_LABELS.png and TOP_LABELS.png files you can clearly see what belongs where. There you can find the designators for every part from the BOM. For example: according to the BOM there are two 47 Ohm resistors (Designators = R34 & R27), which you can clearly find on the TOP_LABELS.png…
