[SOLVED] How to burn a 240p test suite PS1 ?
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › [SOLVED] How to burn a 240p test suite PS1 ?
- This topic has 10 replies, 3 voices, and was last updated May 22, 2019 at 3:21 PM by
vol.2.
December 3, 2018 at 1:51 PM #24121
Hello !
How to burn a 240p test suite for PS1 ? I’ve found the Github page, I’ve seen here and there that I need the .cue and .bin files in the binary folder and I found them too. What do I need to do ? Burn those two files (.cue and .bin) on a CD-R (at the lowest speed possible I guess) ? And that’s it ?!Sorry, it’s probably a noob question but the last time I burnt a CD we were still in the 90’s
(and yes, my console has a modchip, bought a random PS1 last week and discovered that there was a modchip in it while cleaning the machine. Even the previous owner didn’t know about that)
Thank in advance !
December 3, 2018 at 2:48 PM #24124Yup. Use something like ImgBurn to write the bin/cue to a blank CD, and use whichever speed is recommended for the media.
December 3, 2018 at 2:55 PM #24125Thank you. Do I need both the cue and the bin, or any of those two ? I’ll download ImgBurn right away
EDIT : oh… The .cue isn’t what I expected it to be. When I open it I get this :4 lines (3 sloc) 77 Bytes
FILE “240pTestSuitePS1.bin” BINARY
TRACK 01 MODE2/2352
INDEX 01 00:00:00I understand its purpose (giving instruction to the PS1 to read the .bin I guess) but what am I supposed to do with that ? Do I need to create a text file with a .cue extension and copy paste those 3 lines ? Or something like that ?
Sorry for those stupid questions but I can’t find any tutorials.
December 3, 2018 at 3:49 PM #24128You need both. The cue file describes how the BIN is to be written to the CD. Select the cue file in your burning software and it should automatically pull the bin in.
December 3, 2018 at 4:09 PM #24129You’re a star ! It works ^-^
For people who are wondering :
1: Go here https://github.com/filipalac/240pTestSuite-PS1 and click on the “Binary” folder
2: Download the “240pTestSuitePS1.bin” file (around 800Ko)
3: Download ImgBurn
4: Create an image to your CD-R using ImgBurn by using the .bin file
5: Verify that the track is the same as you can see in the .cue file (you don’t need to download it), it should be good as it is.
6: Burn the discIt sounds even more complicated than it is, basically, burn the .bin file on the CD-R and that’s it.
Again, Thank you nmalinoski !
December 3, 2018 at 5:53 PM #24133Generally, you want both the .bin and .cue. Like I said, the .cue describes how the .bin should be written to the disc. If it needed to be written in a different mode, or you’re burning a disc with multiple tracks and/or a mixed-mode disc, you absolutely need the cuesheet.
May 21, 2019 at 2:58 AM #26285I’m having a hell of a time getting the 240p test suite going on my ps2. I tried burning it with a bunch of different programs, but I think it isn’t working because I’m using a CD-RW, and I’ve been readin you need to use a CD-R. So I thought, maybe I can just load it directly on my HDD from a USB, but I can’t figure out what format to do that in. I have McLoader and uLaunchELF and SMS, and HDLoader. So I’m thinking one of those programs can probably run something I can create with the files from Github, but I can’t seem to figure it out.
Any ideas as to just getting it on my HDD?
May 21, 2019 at 3:03 PM #26293If you’re just trying to launch it from something like HDL or OPL, hook the hard disk up to your PC and use WinHIIP to add it.
May 22, 2019 at 1:13 AM #26312Thanks nmalinoski, that’s good info. This is basically exactly what I was trying to figure out. Unfortunately, someone over on the PS2 reddit has informed me that the 240p test suite will not work properly on a PS2. Apparently, the video is a mess and it’s unusable, so it’s back to the drawing board. I’ll have to get my real PS1 out of storage and figure out how to burn it. I’ve been told that I have to use specfic CD-Rs that work with PS.
May 22, 2019 at 4:37 AM #26314In my experience, most any CD-Rs work with the PS1; you just need to get the swap trick down, or install a mod chip, and make sure that your CD assembly is in good condition.
May 22, 2019 at 3:21 PM #26324Thanks, I already have my PS2 soft modded. I did the swap thing years ago and I’m still using the memory cart that has mcloader and stuff on it. Everytime I try to burn a CD-R, my PS2 says it’s a bad disc. It doesn’t have a problem with the James Bond swap disc I burned like 7 years ago, that CD-R still seems to be working as a game. Either I’m screwing up the burn process, I’m using bad CD-Rs, or I’m missing something really simple that’s entirely escaping me.
