IR LED blinks, but OSSC doesn't respond to remote commands
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support IR LED blinks, but OSSC doesn't respond to remote commands
  • #15992
    pcbrown
      Hello,
      I just received my OSSC and while I love it so far, I didn’t realize how important the remote was. I purchased a programmable remote made by RCA (https://www.amazon.com/dp/B003EYV210/ref=asc_df_B003EYV2105214098/) and set it to auto-cycle through various manufacturer codes, and once the OSSC’s IR-associated LED began to blink, I assumed I had landed on the appropriate programming for the remote. However, I can’t seem to trigger any commands via the remote, despite the LED blinking. For further reference: Every button I press on the remote triggers the LED blink.
      Curious how else I can troubleshoot, or, if the remote is somehow sending signals within the range of the NEC IR profile, but not the appropriate ones.
      Thanks in advance for any advice!
      #15997
        Have you done the remote control setup procedure on the OSSC itself? http://junkerhq.net/xrgb/index.php?title=OSSC#Remote_control_setup
        #16000
        pcbrown
          Well, I’m embarrassed to have missed that step! It did the trick. Thanks so much!
