Hey nice people.
My setup currently has 2 Bandridge manual SCART switches. Up to a few days ago I was using 9 SCART inputs, the first switch output would connect to one of the second switch inputs, and the second switch output would connect to the only SCART input on the TV that supports RGB. Now I have 10 inputs and need to combine both SCART switches outputs into one cable.
Is there any Y cable that combines 2 SCART inputs into 1 SCART output? Since I only use 1 device at a time, only 1 signal at a time will be using the cable. I could use one of those devices that combine several SCARTs into one (or vice versa) but that will add more cables and more points of interference/noise/signal degradation.
