Issue with Samsung Q60 QLED TV and SNES w/ the ossc.
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Issue with Samsung Q60 QLED TV and SNES w/ the ossc.
  • #48260
    drewb583
      Hi all, I’m using a Samsung Q60 TV and the snes with the ossc. I’m currently using the FireBrandX profiles and i’ve used other displays with my SNES that work completely fine, but my TV is dropping sync with the ossc (no red light is being shown however.) Is there any reason why this is happening? On my monitor through OBS it seems to be working fine (I have a HDMI splitter that I run to my pc)
      #48268
        Does your SNES have a dejitter mod?
        #48279
        drewb583
          It doesn’t have a dejitter mod, but i’m just confused because it plays nicely with other displays? Is it a samsung only thing?
          #48335
            Definitely not a Samsung only thing, I’d say more than 50% of TVs are affected by it.
            I’m hoping to have more dejitter boards in stock within the next few months, shortages allowing.
            #49782
            Michal Stepien
              I have SNES PAL 1CHIP with FFVIMAN mod. I use RGB SCART Cable PAL Luma-Sync. If I install dejitter board, do I have to change cable to the PAL CSYNC version or to NTSC version? Right now I have no problems with my HDTV but I’m going to buy Samsung QLED.
              #49805
                Dejitter is only needed for NTSC consoles (or PAL consoles running NTSC software via SuperCIC).
