Issues with PAL Jaguar RGB and C64 via S-Video transcoder
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Issues with PAL Jaguar RGB and C64 via S-Video transcoder
  • #7911
      Both these systems seem to be broken in firmware 0.71. The LCD will display the correct frequency sometimes, other times crazy values like 794i. Even when the correct values are shown the OSSC will not sync.
      Edit – Tried all the way back to 0.67 Rel firmware and still the same problem.
      #7916
        Temporary workaround for these issues:-
        1) Connect the console/computer via the AV3 input (D-Sub15/VGA). To do this you will need a suitable adapter. Separate sync is not required so any passive SCART to VGA should work.
        2) For the C64, set H-PLL Pre-Coast to 4 and H-PLL Post-Coast to 4.
        #7961
          AV3 input requires TTL-level c-sync, so a passive SCART->VGA adapter is not necessarily enough.
          #7985
            Ah right my bad, all my setup is wired for c-sync/clean sync, it is true.
            #8149
              Update – C64 works when connected to AV1 if analogue sync LPF is set to max.
